CPU-Z, see what it says after.
You heard of Microsoft paint? it comes free with every copy of windows since dinosaurs roamed the earth.
Wot cpu cooler do you have?
I see at 4.2ghz the bios has auto adapted the voltage to 1.318v.That will run the cpu very hot without adequate cooling.
Memory is now running correctly.
You should learn about Vcore offset now, so instead of the board auto increasing the Vcore for you.
You set the offset to be whatever you want to add to the stock voltage.
So at stock speed if your CPU uses 1.15V but needs 1.3V for 4.2GHZ, you set the offset to +0.15v.
Those are just numbers I picked out of thin air, so dont use them exactly.
For gigabyte boardsI found this - http://www.tomshardware.co.uk/forum/id-1722630/intel-god-quick-dirty-guide-4ghz-haswell.html
I was wondering what the options 2,4,5 are called on my BIOS because I dont find anything with the same name or similar to what is said in this guide -
2. Set CPU cache Multiplier also called the Ring bus multiplier to 35
4. Set CPU Cache Voltage also could be called Ring Bus voltage to 1.20v -1.25vv
5. Set Vrin also called "CPU Input Voltage" To 1.9v - 2.1v
Does it still reduce the core speed and the voltage at idle?
The voltage yes, ideally.
What you need to do instead of setting a voltage, type in Normal or press PageDN or PageUP till Normal appears, then underneath the offset option should go from being greyed out and unusable to being usable.
The offset is what you want to add to the stock voltage to reach say 1.269
So if stock is 1.1V and you need 1.269V to be stable, set offset to +0.169
And it will add that value when underload.
