I now have a loose spoke :/
Worth riding 10 miles to the lbs on? Or just put the wheel on my back again?
If it's just 1 then tighten it up! Although you'll usually find that the neighbouring spokes have loosened too, especially if you've ridden on it (nearly always the case). Check how true it is afterwards, this can be a test of patience with these Giant wheels! I'm waiting on new nipples to arrive, but may hold off rebuilding it until I have a wheelset to use.
I need new wheels these stock ones really are bad. Broke my living room window today though so it'll have to wait!
These are what grudas has put a ton of miles into and not even had to true -
http://www.wiggle.co.uk/campagnolo-khamsin-asymmetric-g3-wheelset/
I'll be ordering a pair today as in theory I get paid today!
Edit: Maybe not! Rosebikes have Mavic Aksium One wheels for £115 plus 10% off this weekend plus £10 voucher for first orders making the total sub £100!
Cracking deal really, but around the £100 mark there are lots of options.
No, dont ride it.
It would be fine but it'll put a lot of stress on the other spokes and they'll be more likely to break in future.
They'll work themselves loose too!
Possibly, is it a tyre off job?
Only really when advanced truing a wheel (it's just easier to see/judge with the tyre off), basic truing you should be ok with it on.
Guys, cotton caps, talk to me. I have a big head and got
one of these and can barely get it on my head, when I do it's too tight to be comfortable! This is without even thinking of putting a helmet on top! Everywhere I look they're 'One-size-fits-all-except-roady'
Had a slight issue last night (in the wet) and this morning where my rear brake isn't releasing. Going to give it a good clean at lunchtime, it's been wearing much more than the front for a while and is near the end of the pads. I think it's just dust/road crud from the wet weather either in the caliper joint/spring or on the cable gumming it up. Seems to be never ending problems at the moment!
Changing Brake/Gear cables I haven't done yet, although I really should! Is it safe to just buy inner cables? Which does everyone recommend for all weathers? Jagwire? Or is that just the outers?
