New Puter not Booting :-(
8 Jun 2013
any help/advice greatly appreciated:
as per my other threads, i did my first build in March. Surprisingly, all went well, got the machine up and running, few things installed, Win7 updates etc etc. a few days later i finished the build, putting in my second SSD and a hybrid drive, and i didn't fire the machine up, thinking nothing untoward would happen except perhaps Windows telling me it had found new hardware.
having just finally got my new puter room ready, i fired the machine up and i'm getting nothing. the MOBO (ASUS Z97a) has the white lights, the case fans fire up, there the little "blipblip" bit at the get-go but that's about it. my Noctua isn't spinning but i don't think it fires up until the temp's up? i tried my vid cable in the 980 ports and the MOBO ports just in case but i'm getting nothing.
rest of the kit:
corsair rm750 PSU
16GB Kingston hyper x
TIA
The heatsink fan most certainly will spin at all times.
If it was fine before being moved around then its going to be a lose connection or part.
You will probably have to take the gfx card out to use the onboard connections.
The basic parts needed to work are,
Board/CPU/Cooler and a stick of RAM.
You dont need any drives connected to at least get the POST screen to display.
Spot on bud, my big ATX power lead was loose, musta knocked it when shoving the other stuff around!
many thanks :-)
