And how do you know what my experience is? (Just because I'm not linking to stuff in my sig)?
I have tried my damnedest not to sound like a #### here but you keep pushing this despite my already explaining this over and over again.
I don't know what your experience is but it appears you don't understand the difference between a Physics API and Physics libraries.
The Physics API is the engine, in the case of Bullet being an API as opposed to libraries is a blank canvas, it is the tool to make whatever is in your head a reality.
Physics libraries is a basket of someone else's paintings. (Games Works)
So you may now see there is no need for me to rewrite or make my own Physics API, Bullet is what i need it to be, a tool-set to make my own stuff from scratch.
Another reason this is important to me is because i do not need to worry about what hardware the end user has in his PC, Bullet really does not care about that, it just does what its meant to do on all platforms and do it equally well.
Is there proof it runs equally well? (Genuine question)
Also, since you can produce something that does what GameWorks does, then presumably you've used GameWorks too?
So you know what it gives you in regards to HairWorks so that you can recreate it?
I've seen one of your videos. You really can't.
If you think you can, you've got something missing upstairs.
It uses open source compute instructions so the only thing it depends on is how powerful the hardware is, not what it it.
Bullet will do Hair Works / TressFX yes, because i can tell it to do that (Blank Canvas)
You may have seen Nvidia's Grass Works demo, here is my first attempt at it using Bullet, its not as pretty ecte... but thats down to my skill and the work i put into it, which wasn't a lot, the 'Physics' of it is there.
I know technically its not like Hair Works, its grass not hair, but they are actually the same thing in technical terms.
Very nice humbug, In my opinion it show that grass/hair effects can be done with non hairworks/tressFX stuff and as you say it may not be as good as their demos but you are just a hobbyist programmer and not a full time game programmer so that is to be expected.
As to the main question of why Gameworks and tressFX style libraries. Let me ask you all this. Why are we using windows and not still using dos, because it makes things easier.
Isn't that the case with PhysX too? Performance is based on CUDA cores? So only depends on how many CUDA cores you have?
If AMD have much stronger compute instructions then it seems like it won't run equally well?
Also, you didn't mention if you'd tried using GameWorks as a basis for comparison?
I'm using it because it does what I want it to do. Also it doesn't have that pesky 640K RAM limit thing.
Which is presumably why developer use GameWorks rather than doing it themselves. I feel at some point this turned into a what Humbug wants it for rather than a what game developers want it for.
Maybe the developers don't get a choice because the decision was made much higher up that it would be used.
Otherwise we can only assume the developers as Ubisoft and CD Projekt (or anyone else that uses GameWorks) don't have Humbug's level of knowledge about these things and were unaware of blender and Maya.
Agree with all of that, AMD themselves are also not whiter than white, why can't Nvidia run TressFX in Linch-Doom? thats what i would like to know, AMD? humm?
I questioned a Lichdom developer on this very point and I found their attitude to be very strange. They said they purposely disabled TressFX on Nvidia GPUs as: "We delivered TressFX on AMD hardware as part of our partnership with AMD.".
I reminded the developer that according to AMD's own material the performance hit is the same on Nvidia and AMD GPUs and it goes against AMD's ethos to disable non-proprietary, vendor-agnostic features and fosters the impression that TressFX is a locked, closed-source entity like GPU PhysX. This couldn't be further from the truth, it would be a negative for TressFX to be in the same category as PhysX, so I think this is a developer decision. However, AMD should really be much more vigilant and make sure things like this do not happen as it hurts their brand image.
After informing the developer of this I was met with complete silence. I found that others have also brought this up only to be met with silence as well.
Here is a link to my thread: https://steamcommunity.com/app/261760/discussions/2/620700960748580422/
I was aware of this before LoadsofMoney brought it here and im sure its because he was reading my conversation on another forum which resulted in this getting brought up, then some hours later it gets posted here, i wanted info that AMD asked him to disable it which he would not produce, i was going to then post it here to show that developers can be biased as its not something AMD would ask for when it comes to TressFX or any other of there compatible features.
If it was found out that AMD asked for such action then they would be getting a serious bashing from me because blocking things that work and not allowing others to optimized for there hardware even after release is BS.
Yes, it would be crazy for AMD to ask the developer to disable the feature on NVidia GPUs given the image they are trying to cultivate. I just don't see it being likely. They didn't ask for it to be disabled in Tomb Raider which was a much higher-profile game, so why here?
By the way, I really liked TressFX on my GTX 690 in Tomb Raider, I was hoping I'd see more of it and that it would evolve to be even better. The only mention of it has been the new Deus Ex game and I assume the new Tomb Raider; I wish AMD would get it in more games as I think it's superior to Hairworks.
Well TressFX first iteration had less of performance hit than Hairworks.
TressFX 2.0 is used in Tomb Raider Definitive Edition on PS4 which is even more optimized,
Rise of the Tomb Raider on the Xbox one will have even even more upto date TressFX implementation.
Good job bringing this up with the Dev ^^^, its a disturbing trend that does seem to be true, some Dev's taking Hardware Vendor sides, it seems AMD do have them too..
I tryed to bring up a whole series of things Game Works and general fairplay on the W3 forum, like paying the same money for a product with lesser features depending on hardware.
It wasn't long before i had a Mod following me round deleting my posts, some points and questions they will let go, but if you get a little to close to something that could do them real damaged they have the forum Mods go into damage control mode.
