Can anyone tell me what overclocks in general peeps are getting please ?![]()
Boost is 1200 if I up the power and temp target and don't touch anything else.
Well with stock volts I can get 1420 stable, Anything higher requires more volts.
Memory seems happy at 8GHZ although I might back it off as I can't see much perf increase just yet.
Easy way to test this....
Run Battlefield 4 at 4k with Ultra settings and then put the resolution scaling to 125%![]()
It hath arrived !
Got an extra 3 years warranty for free on this too through Zotac, 5 years total, Not bad at all
Mine has just arrived too. Buyers remorse![]()
You seem ****** off anyway without spending 3k so it's okay
You are simply stating what everyone knows anyway that todays tech can't run that resolution maxed out. I'm pretty sure he knew that before spending 3k, as anyone with an ounce of sense would.
Lets wait and see if he can actually crank the settings up![]()
I'm new to GPU 'flashing', hope you can help me... I got the 4-pack of BIOSes from elsewhere, is the 425 SC one the baby to use?Only way to stop that is by flashing a BIOS with a higher TDP.
Mine was doing the same.
Thanks, that helped greatly although that would not work as I was using a more up-to-date nvflash that did not require me to do the --protectoff or the -4 and -5 bits in the end. BUT Thanks, that's got me to same speeds with no stuttering in gamesIf you're on water you could use a BIOS with higher voltage, I'm using the maxair bios on the stock cooler.
To flash the card follow these instructions:
even without KBOOST so that's a treat!Same happened to me... took 10 days from order... you can't beat OC (when they have stock) for service! It all arrived in the end though so you'll be OK.not sure if im allowed to ask this if not please delete.
im just wondering has anyone ever order direct from ek? i ordered a waterblock and backplate from them 6 days ago and for some reason my order is still pending even though it said they had stock. I've sent 2 emails and they still haven't wrote back to me.
i would have ordered from overclockers but they had no stock at the time
