Just buy the pack of about 20 tubes from the pound shop and use one for each application then discard.
In all my years of glue sticking (glue sniffing?) I have never come across a situation that requires the advice of GD on what superglue is best that will sit on a shelf for a year?
Just buy one, if it needs to be replaced a year later, replace it. It's not like it costs £25 a tube.or something.
I've been dimpled![]()
pffft ive done the testing in labs at uni , the metal fails before the glued joins do !
so if anything be worried about flying in airliners made of weak metals![]()
Hang your head in shame.
I think I might try that Gorilla Glue but woe betide if I come to it in 2 years and it's clogged up.
I think you're missing the point by a long way.
My post was at 22.11 WHEN I NEEDED IT.
Why should I have to get in my car and drive 2 miles to a 24 hour Tesco so I can fix the item?
All I want is a bloody bottle of super glue I can re-use when needed.
You mean Amazon?Google "single use super glue" Scotch do multi-packs over at the rainforest place
You mean Amazon?
