- 20 Apr 2004
- Rugby
So exactly the same as the cheapest Titan X (Palit) then? Doubtful.
As far as I know the cheapest Titian X is £799 and not £699
I'd be delighted at £559.00, ill be going with a reference cooled card this time. No more mistakes with aftermarket cooled models.I am going to go for £559 cheapest and with top end hitting £619
The dynamics are different this time, 3GB on the original Ti was a real niggle, but the 980Ti is a TX with 6GB, which is still plenty... can't see it being much less than 700 as why would they chop their legs off like that if TX is still selling out?
Good move![]()
Finally, since the GTX 980 Ti uses a cut down version of the GM200 GPU this will very likely mean that the card will have a two segment memory system like the GTX 970. We don’t know the exact proportions of the memory segments, but we estimate that something like 5.5GB + 0.5GB is likely.
If the 980ti does have a memory setup anything like the GTX 970 did then I will not be buying one (two)......Finally, since the GTX 980 Ti uses a cut down version of the GM200 GPU this will very likely mean that the card will have a two segment memory system like the GTX 970. We don’t know the exact proportions of the memory segments, but we estimate that something like 5.5GB + 0.5GB is likely. Thankfully, because the 980 Ti has a lot more memory than the GTX 970 to begin with, this should not be an issue, as 5.5GB is plenty of memory to begin with.
Read more: http://wccftech.com/nvidia-gtx-980-ti-specs-benchmarks/#ixzz3asyQXojh
Once bitten twice shy lol.
This card and an upgrade later in the year to skylake 6700k should see me ok for a few years.
Hey setter mate, whats making you want to go reference this time?
I havent upgraded in a long time but want to pick up two of these puppies and watercool for 4k.
