- 30 Jul 2007
Id go cheapest per gb...as they are same class devices...the samsung 850 has the edge in performance..but the 840 firmware debacle may put some off samsung.
That said, there’s reason to think that the 850 EVO wouldn’t have the same problems. One of the advantages of using an older NAND process is that the cell structures were more robust to start with. It’s entirely possible that TLC NAND built on 40nm would dodge problems that affected smaller process geometries. We’ll be keeping an eye on this problem over time — if Samsung can’t eliminate this issue once and for all with a second update, the 840 EVO is going to be permanently tarnished.
i would go for 1x1tb
advantages of 1x1tb
higher performance-larger device tends to have best performance (1x1tb vs 1x500gb).
less sata sockets/case space used..more options later down road
cheaper - £/gb tends to go down as size goes up
advantages of 2x500gb
Backup of OS drive as drive rather than partition - dedicating an entire disk (rather than partition) to the os, makes OS backup/restore a little bit more fool proof for piece of mind..
Performance - in theory 2 drives utilised fully at same time faster than 1...but highly unlikely both drives would be fully utilised at same time...esp if 1 is os and 1 in games.
For general PC use and gaming is raid 0 really relevant? Is raid 0 even relevant with SSD's? Or is it just pointless (would there be a performance boost)
Yes RAID 0 is relevant with SSD's and would give a performance boost, whether or not its useful to you for general PC use and gaming, only you can answer.
I wouldn't touch RAID 0 SSDs with a bargepole, you're doubling your chance of failure for a performance increase you're unlikely to notice.
I wouldn't bother with PCIe SSD in a gaming rig as having one can remove PCIe channels from your GPUs.
When people say double your chance of failure though it is only really an extra 1% chance, i have not had an SSD fail so far (touch wood).
Seems more taboo than anything.
