- 29 Aug 2010
- Cornwall
Depends on your case, assuming they're on a 120mm rad a 750d can easily accommodate 4 of these. Would look a bit mad but it has more than enough mounts to do it.
Be interested to see if they have a better iteration of clock boost, nvidia's implementation is far more interesting, all amd's does is start turning down clocks due to heat![]()
But consider that it's also possible that this person would have an AIO CPU cooler too. If they're getting 4 390/390X they may well have a beefy enough CPU to have gone with a 240mm rad on the CPU.
So you'd need 6 120mm fan mounts. Since radiators are rarely 120mm x 120mm you'd probably couldn't fit them all next to each other either. So you'd probably need more than 6.
