I'm not sure about the cooler, it will be beaten by similarly priced air coolers in terms of noise and performance. The only AIOs worth looking at are around the 240mm and 280mm range
I assume the budget is £1300?
YOUR BASKET
1 x EVGA GeForce GTX 980 Superclock ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2983-KR) £439.99
1 x Gigabyte Z97X-Gaming 7 - Devils Canyon Core i7 4790K CPU & Motherboard Bundle **£25 Saving** £393.98
1 x Phanteks Enthoo Luxe Full Tower Case - Black £119.99
1 x TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED316G2400HC11CDC01) £99.95
1 x SuperFlower Golden Green HX 750W "80 Plus Gold" Semi-Modular Power Supply - Black £77.99
1 x Crucial BX100 250GB SSD SATA 6Gbps 7mm Solid State Drive (CT250BX100SSD1) £71.99
1 x Phanteks PH-TC14PE CPU Cooler - Red £69.98
1 x LG 24x DVD±RW SATA ReWriter (Black) - OEM GH24NSC0.AUAA10B £13.99
Total : £1,305.56 (includes shipping : £14.75 Ex.VAT).
This cooler is a beast, looks decent with the red scheme and is very quiet and cool running
There is the MSI 980 which has a red and black cooler shroud which would fit well
As you posted, 750W is enough for 980 SLI, or you could go for 850W (https://www.overclockers.co.uk/showproduct.php?prodid=CA-017-EA&groupid=701&catid=123&subcat=2466) which gives you a little more headroom
Some alternative coolers
YOUR BASKET
1 x Corsair Hydro H110i GT 280mm Extreme Performance Liquid CPU Cooler (CW-9060019-WW) £99.95
1 x Cooler Master Nepton 240M AIO Cooling Solution £79.99
1 x Raijintek Tisis Dual Element Extreme CPU Cooler £49.99
1 x Phanteks PH-TC12DX CPU Cooler - Red £38.99
Total : £278.52 (includes shipping : £8.00 Ex.VAT).
You could also wait for the new AMD cards which should be coming soon, especially the R9 390 and 390X
Cashback - https://toptechcashback.com/uk/en/p...il&utm_term=0_c199b69777-4c4a227cf4-212867289
YOUR BASKET
YOUR BASKET
