- 6 Jan 2013
- Rollergirl
G-Sync is the dugs nuts.
G-Sync. Cause **** everything about multi card setups.
But explain to me how you can tolerate 30fps over turning a few settings down.
Whats exactly wrong with the Acer Predator 4k G Sync?
Not every game, things like Witcher play well at 30FPS+, first person games however I need more.
Witcher has been the only game that I've been unable to get 60FPS+
Something to do with the after sales service and dead pixels and screens upon arrival by the looks of it....
I have the Acer g-sync monitor and have owned your sammy as well. The response times are top quality TN much faster than the sammy and no overdrive issues. The input lag is as low as you can get and faster than the sammy. The calibrated image was great as well, not a lot different to the sammy. Not a heavy anti glare filter either.
As i have 2 TX's though i have ditched the Acer for a 32" Asus IPS. Witcher 3, DA inquisition, GTA V to name a few run at ultra 60fps pretty much all the time so no need for g-sync really for me. Plus g-sync can't alter the fact that low fps are laggier and have more motion blur even though the judder is gone.
For me 1 TX is not enough for 4k ultra even with g-sync it's just too low a fps but that's just my preference.
Always good to hear thanks for the input helpful when someone else has taken the same steps.
So in your opinion get a second TX and stick with the Sammy, I'm not fussed about the golden 60fps as long as its smooth which GSync seems to achieve, but another TX will future proof me I suppose.
Though saying that theres nothing more annoying than spending another 900quid on a GPU and the drivers don't give you SLI, they very reason I moved from AMD.
It's not just driver issues per se either, and although SLI is considered better than crossfire generally, sometimes SLI just will not get on with some games with regards to stutter and microstutter. Out of the games I currently own/ play the following just flat out stutter with 2 cards, no matter what, and the only way to play them smoothly is to use one card...
- Far cry 3 (not got 4 yet, but from what I've heard it's simialr)
- Titanfall
- Watchdogs
- Crysis 2 with MaldoHD mod (weird one that!)
Make of that what you will, there are bound to be others that I haven't got or played.
There are other games I have where I've had to write little readme files with personal notes and tweaks for getting 2 cards to run smooth. These currently include off the top of my head (there are more)
- GTA5
- Witcher 3
- Skyrim
- BF4
- Bioshock Infinite
- GTA4
Interestingly, a lot of these have needed special tweaks and attention since getting my Gsync Rog Swift. Although Gsync is a 'fix' for some games in terms of dropped frames and vsync type 'judders', it is not a cure for stutter or microstutter WHEN YOU HAVE SLI, in certain games. It can actually make some games feel worse when stutters happen, because it's so smooth normally it exacerbates it.
Take GTA5 as one working example, as it's new. This is what I have to do to get perfectly smooth gameplay using 2 780Ti's in SLI, along with my Gsync Rog Swift:
- Set the ingame HZ setting to 60 (which is actually listed as 59 bizarrely)
- Use bandicam or Dxtory to limit the framerate to 59
If I run the screen at 120Hz, or 144Hz it is jittery as hell. If I try any other combination of framerate limiter number it is jittery as hell. It's a weird but odd fix and just one example. Other games (like Skyrim with ENB) need different and sometimes far more elaborate tweaks and workarounds!
Having said all that I still love Gsync. One powerful card and Gsync is amazing![]()
Get a Swift and another Titan, pure bliss.
If money is not an issue another gpu is nice and if your happy with the response times and input lag of the sammy it's a really nice TN monitor when calibrated, can't fault it in that regard even compared to IPS directly viewed. The only thing in my mind is the pascal gpu's due out maybe next year with that new memory (sounds good for high res gaming) and perhaps a hell of a lot more power. One of those would maybe be enough for 4k who knows. Only you know what you can afford upgrade wise and how often but those new gpu's might be something special. At least 1 TX can guarantee ultra 30fps or more in games which is nice. Below 30fps on dead rising 3 with 1 titan black was painfull.
