Hi Guys
We are pleased to announce the Antec Signature S10 is available to pre order from OcUK right now.
This case is absolutely stunning in real life, in my opinion, the best case Antec have ever made.
There are a number of premium features which set this apart, the space and layout really is the peak of the Antec range and it shows that they are really putting a lot of thought into making a great flagship product with the S10
In my opinion, this is making every other case in its class look fairly uninteresting.
Kudos Antec
Antec Signature S10 Full Tower Aluminum Case - Black @ £399.95 inc VAT
Introducing the NEW Signature Series of Cases featuring the revolutionary Three Chamber Design. Built from the ground up, the new three chamber chassis reduces energy use and system noise by using scientific principles to create highly efficient cooing and airflow inside each chamber.
Features
- Supports SSI CEB, E-ATX, ATX, Micro-ATX, Mini-ATX Motherboards
- 10 Expansion Slots support 4 graphics card up to 13" [330mm]
- 14 Drive bays - 8 SSD, 6 HDD
- 6 Cable routing holes (rubber grommets) with 1" [25.4mm] behind motherboard tray
- Channels for routing cables behind motherboard to front chamber
- Flexible Power Supply Mount (standard or upside-down)
- 4 USB 3.0 High Speed Ports on top panel with audio i/o
- Maximum Size CPU Cutout 8 5/8" x 5 7/8" [219mm x 149mm]
- New Three Chamber Design - New chassis reduces energy use and system noise by using scientific principles to create a highly efficient cooing and airflow design
- Each chamber is a separate thermal zone for maximum temperature control
- Micro-mesh filters protect the independent air intake for each chamber
- Choice of Aluminum or Tempered Smoked Glass Doors blend with any environment (this unit Aluminium)
- Strategically placed fans draw cooler air into case using top down airflow
- Fans consume less energy, make less noise, and more effectively cool the system
- Flexible mounting options for power supplies - standard and upside down
- Top I/O panel with 4 high speed USB 3.0
- Room for 5.25" short depth fan controller, card reader, or other device
Specifications
- Case Type: Full tower with Aluminum Doors
- Colour: Black with Brushed Aluminum Doors
- Product UPC: 0-761345-80010-5
- Dimensions: 23.70" (H) x 9.05" (W) x 23.22" (D) / 602 mm (H) x 230 mm (W) x 590 mm (D)
- Weight: 39.05lbs / 17.71kg
- Cooling: Motherboard Chamber - 2 x 140 mm top exhaust fans, compatible with liquid cooling radiators up to 280 mm, 3 x 120 mm intake fans, compatible with liquid cooling radiators up to 360 mm, 1 x 120 mm rear exhaust fan, compatible with 120 mm radiator for water cooling, Washable air filter - Large
- Power Supply Chamber - 1 x 120 mm intake fan (optional), Washable air filter - Medium
- Hard Disk Drive Chamber - 1 x 120 mm exhaust fan, Washable air filter - Small
Drive Bays: 6 x Quick Release 3.5" Bays, 8 x Quick Release 2.5" Bays
- Motherboard Size: Mini ITX / Micro ATX / Standard ATX / XL-ATX / E-ATX up to 12" x 13" (304 mm x 330 mm)
- Top I/O Panel: 4 x USB 3.0, 5.25" Short Depth Bay for Fan Controllers, HD Audio In and Out, Power Button
Only £399.95 inc VAT.
ORDER NOW
Kudos Antec
Features
Specifications
ORDER NOW
