Watercooled and 2 8 pins doesn't scream performance per watt for me![]()
Then neither will the 980ti I guess Or Tx for tht matter... Too bad.
I know 32nm half node was cancelled, just like half node.20nm.
But my linear point still stands. They had to.chop a lot out of the 6970 especially shaders to get it to work on 40nm. Humbug feels it's fine to use 28nm so it must be all ok.
).Then neither will the 980ti I guess Or Tx for tht matter... Too bad.
Don't mind a lot of watts if there's a lot of performance, god only knows what my 7990 uses currently (overclocked and overvolted on water).
When Humbug gets up around 2pm, you will be for it![]()
Difference being nobody stated those cards would be good performance per watt, whereas I've seen a lot of people expecting under 200w from AMDs new flagship because of HBM.
Which still does not change the fact.
Well seen as we have known for a while now the power envolope is same as a 290x with it likley to use slightly less power and thats about 300 watts and weve seen the Tx and Ti use upto 288 watts its only 20 watts diference. Post above goes power efficency... Only time you woukd assume that is when we know the performance of the new AMD card. We dont so if hes all about power efficency then 980ti or Tx is probably not efficent enough for him either?
Also not seen anyone expecting 200watt gpu lol bit OTT? More like 50 watts less best case?
But imagine if it does have good performance per watt and they are clocking it to the wall /drool
Looks quite cool though, and the fan looks like it will be much quieter than on the GTX980 hybrids.
