- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
The Antec P50 has landed at OCUK.
Antec P50 mATX Dual Chamber Windowed Cube Case - Black @ £59.99 inc VAT.
The Antec P50 mATX cube case offers amazing levels of cooling potential in a great small form factor. With a streamlined and sleek style you will be the envy of your friends and family with this PC enclosure, heightened by a sexy windowed side panel to show off your prized components.
The dual chambered design ensures that your storage drives and PSU is kept away from the mainboard and GPU area, this is perfect for both cooling for aesthetics. It may be small in size but the features are big, with dual 240mm radiator support, seven fan mount locations, washable dust filters and USB3.0 support this really does set a new standard for compact chassis design, combined with an affordable price this is the chassis for champions!
Features
- Advance cooling system: 3 fans included and 4 additional fan mounts
- 2 x Fan Control: (High/low/off) to achieve the balance between high performance and quiet computing
- Washable air filters for front and PSU intake
- Dual layer sound deadening side panels for quiet operation
- Supports top mounted 240mm watercooling (or 2 x 120mm fans)
- Supports front mounted 240mm watercooling (or 2 x 120mm fans)
- Dual compartment structure (MB compartment and PSU/HDD compartment) for superior heat and air flow management
- Supports up to 300mm long GPUs for high performance gamers
- 2 x front USB3.0 Ports
- CPU cutout for easy CPU installation
- Routing holes for easy cable management
- Easy access to the front and top bezel for easy system maintenance
Specifications
- mATX and mITX motherboard support
- Expansions Slots x 4
- I/O Ports: 2 x USB3.0, 2 x USB2.0 and HD audio in-out, 2 x Fan controller
- Max CPU cooler height: 130mm
- Windowed Side Panel
- Dual fan controllers
- 2 x 2.5" SSD tool-less mounting
- 3 x 3.5" HDD tool-less mounting
- 1 x 5.25" removable ODD bay
- Standard ATX PSU support
- 2 x 120mm front intake fans included (motherboard/CPU/GPU chamber)
- Optional 2 x 120mm top fan mounts
- Optional 2 x 80mm rear fan mounts
- 1 x 80mm front intake fan included (PSU/HDD chamber)
- Watercooling support: 1 x 240mm top radiator mount, 1 x 240mm front radiator mount (not fro 240mm top mount the 5.25" bay must be removed)
- Dimensions: 330mm (d) x 260mm (w) x 312mm (h)
- 3 Year Warranty
BUY NOW @ £59.99 inc VAT.
Also check out the mesh panels.
WHITE P50 TOP MESH PANEL @ £6.95 inc VAT
BUY NOW @ £6.95 inc VAT
RED P50 TOP MESH PANEL @ £6.95 inc VAT
GREEN P50 TOP MESH PANEL @ £6.95 inc VAT
BLUE P50 TOP MESH PANEL @ £6.95 inc VAT
Here are a few pics of this with our UFO Fans installed.
Here are some pics of the case with the different top mesh panels.
Features
Specifications
- 3 Year Warranty
