Antec P50 crashes into stock at OCUK!!!!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
The Antec P50 has landed at OCUK.
Antec P50 mATX Dual Chamber Windowed Cube Case - Black @ £59.99 inc VAT.
The Antec P50 mATX cube case offers amazing levels of cooling potential in a great small form factor. With a streamlined and sleek style you will be the envy of your friends and family with this PC enclosure, heightened by a sexy windowed side panel to show off your prized components.
The dual chambered design ensures that your storage drives and PSU is kept away from the mainboard and GPU area, this is perfect for both cooling for aesthetics. It may be small in size but the features are big, with dual 240mm radiator support, seven fan mount locations, washable dust filters and USB3.0 support this really does set a new standard for compact chassis design, combined with an affordable price this is the chassis for champions!
Features
- Advance cooling system: 3 fans included and 4 additional fan mounts
- 2 x Fan Control: (High/low/off) to achieve the balance between high performance and quiet computing
- Washable air filters for front and PSU intake
- Dual layer sound deadening side panels for quiet operation
- Supports top mounted 240mm watercooling (or 2 x 120mm fans)
- Supports front mounted 240mm watercooling (or 2 x 120mm fans)
- Dual compartment structure (MB compartment and PSU/HDD compartment) for superior heat and air flow management
- Supports up to 300mm long GPUs for high performance gamers
- 2 x front USB3.0 Ports
- CPU cutout for easy CPU installation
- Routing holes for easy cable management
- Easy access to the front and top bezel for easy system maintenance
Specifications
- mATX and mITX motherboard support
- Expansions Slots x 4
- I/O Ports: 2 x USB3.0, 2 x USB2.0 and HD audio in-out, 2 x Fan controller
- Max CPU cooler height: 130mm
- Windowed Side Panel
- Dual fan controllers
- 2 x 2.5" SSD tool-less mounting
- 3 x 3.5" HDD tool-less mounting
- 1 x 5.25" removable ODD bay
- Standard ATX PSU support
- 2 x 120mm front intake fans included (motherboard/CPU/GPU chamber)
- Optional 2 x 120mm top fan mounts
- Optional 2 x 80mm rear fan mounts
- 1 x 80mm front intake fan included (PSU/HDD chamber)
- Watercooling support: 1 x 240mm top radiator mount, 1 x 240mm front radiator mount (not fro 240mm top mount the 5.25" bay must be removed)
- Dimensions: 330mm (d) x 260mm (w) x 312mm (h)
- 3 Year Warranty
BUY NOW @ £59.99 inc VAT.
Also check out the mesh panels. :)
WHITE P50 TOP MESH PANEL @ £6.95 inc VAT
BUY NOW @ £6.95 inc VAT
RED P50 TOP MESH PANEL @ £6.95 inc VAT
GREEN P50 TOP MESH PANEL @ £6.95 inc VAT
BLUE P50 TOP MESH PANEL @ £6.95 inc VAT
Here are a few pics of this with our UFO Fans installed.
Here are some pics of the case with the different top mesh panels.
The most "meh" thing I've seen from Antec in a while. :p
I mean, its just not very good looking for starters. It looks pretty boring. And it doesn't seem very well thought out either.
See they chose a nice high end rig to showcase it. :rolleyes:
That was a build I made just to showcase the UFO fans installed. I don't own a mATX board, the only board I had that fit was my mITX Atom board which I normally have inside my HTPC just to stream movies from my server and Netlfix from the Internet to my TV in my bedroom.
I have a spare GTX 980 Windforce G1 sat on my desk here doing nothing, should I have installed that too? :)
Why didnt they supply cases with a different colour top panel already attached instead of trying to make extra money on top,
Some people prefer the black subtleness? Bitfenix does different colours mesh fronts for their cases too? Same opinion for them?
i still prefer the Antec ISK600M ... and im 97% sure im gonna buy it, its best matx cube case ive seen so far
I do have to say that those fans do look incredibly cool.
What are they like compared to other fans of a similar price?
Well Tom from OC3D has received samples from us, he is doing a review of them, so hang fire for him to publish the review :)
Here is the review from TTL at OC3D, he talks about the nosie levels in this. :)
The fan controller (two of them) is different to the P280, the fan controller is on the front of the case at the top. 3 speed settings.
The one on the P280 was ridiculous, it did'nt protrude out enough. So, if like me you bite your nails, then it was difficult to slide it across.
I even spoke with one of the reps at Antec and he agreed, said it was to late to do anything about it, but would see it was better designed in the future.
how noisy are the supplied fans in these ace?
i have trusted you to ask an RMA question by the way on another matter.
