Anyone here with a Synology NAS with hibernate issue's?
16 Sep 2009
Loogabarooga
Is anyone else suffering with issue after updating their Synology NAS to the latest revision of DSM? I update to DSM 5.2-5565 Update 1 and it then stopped going into hibernate and I got messages about the UPS disconnecting also.
The Synology forum has currently 19 pages from people with the same issue.
I've done the winbnnd stop trick through the cli interface and it's now hibernating again but it alarms me that a major storage provider can release buggy software like this without testing it.
Yes, mine is always awake these days, glad I'm not the only one as I was starting to wonder if it was some sort of external intrusion.
My DS215J is doing the same, so far the only fix I've heard of is an OS rollback. What's the winbnnd trick?
For a company which gets loads of reccommendations they seem to be quite slow on some things...
It's an issue with the latest release, meant to be a fix for it soon.
I don't think they grasp the concept of beta/release candidates. They really should use public (opt in) RCs
Yes, totally agree that they should use beta release so users can decide if to risk the upgrade or not. Surely this should have been spotted at Synology HQ that their devices no longer hibernate?
They do use beta, but they make too many changes between public beta and final, should be an RC.
Fixed!
Version : 5.2-5565 Update 2
(2015/06/09)
Important Information
A thorough investigation has been done, and it is confirmed that DSM and its related packages are not impacted by the LogJam vulnerability because of the way Synology implements OpenSSL in our system.
Fixed Issues
Improved the stability of SHR expansion.
Improved the stability of SMB transfer when the system is being accessed by an excessive number of clients.
Fixed multiple kernel vulnerabilities (CVE-2014-3122, CVE-2014-3153, CVE-2014-0196, and CVE-2014-4699).
Fixed an issue where CPU usage could remain high when widget is enabled.
Fixed an issue where LDAP users could fail to log in to DSM.
Fixed an issue where files could not be downloaded via Windows' terminal.
Fixed an issue where system cannot enter hibernation.
Fixed an issue where some folders with non-English names would become inaccessible via SMB.
Fixed an issue where volumes/iSCSI LUN cannot be displayed after the Synology High Availability system resumes from safe mode with UPS connected.
Installed update 2 on Tuesday evening and initially my DS 412+ refused to hibernate, so power cycled it and it reluctantly went into hibernate and now seems to function fine again.
I will not be updated the DSM like this again in the future, I will look for issues on the forum instead.
I've installed update 2 which appeared to fix the issue but this morning my NAS is sat pinging away rather than hibernating!?!?!
Anyone else have this??
It should always ping, it's hard drive hibernation they had an issue with. The whole system doesn't hibernate.
