Possible Radeon 390X / 390 and 380X Spec / Benchmark (do not hotlink images!!!!!!)
Status
Not open for further replies.
Just a thought: I wounder how these HBM GPU's will overclock? a downside could be that the technology could be very fragile and not overclock much?
Given the 300w TDP which is most likely slightly modest, I would say it's probably fairly flat out already, so similar frequency range to Hawaii. It's going to be a monster in that department
So that will be 2 years then in total ;).
That people have been waiting for something competitive.
Hum Nvidia havent been able to beat the 290 and 290x yet.
I don't do waiting very well I am afraid. Tech moves so quick and a year is a long long time in the tech world.
Absolutly no doubt, from a business perspective, Fiji new due to the change to new node next year making it the fastest and most advanced card in the world today and lead the way for the die shrink. The 390 series allowing superb value and performance with 8gb ram at the mid/high end range.
Godlike I think is the word I use for Fury and it seems to hold up.
My Temple and offerings I made have paid off.
Good for you. I pretty much think the 290 and 290X are well beaten but if it makes you happy and you worship AMD to that extent, I can't fault that. Just be careful of worshipping a false God though :p
Mmmmmm
Does anyone know where is this from?
Cybertron I think. Although I'm pretty sure they moved over here a little while back which is slightly worrying.
I think there's one on the street outside my work but I can't tell if that's just a guy in a wheelchair.
I'm wondering how much of a performance difference the Fury's 8.6TFLOPS will make over Titan X's 7TFLOPs, I have a feeling Nvidia are about to get an extremely large rude wakeup.
Here's the fan details:
Model Name:
D1225C12B7AP-29 (3,000 rpm)
D1225C12B9AP-30 (4,250 rpm)
D1225C12BBAP-31 (5,400 rpm)
Fan Speed:
3,000 rpm / 4,250 rpm / 5,400 rpm
Noise Level:
36.5 dBA / 44.0dBA / 50.5dBA
Airflow:
83.0 CFM = 141 m³/h
116.5 CFM = 198 m³/h
150.1 CFM = 255 m³/h
If that picture is legit then AMD have spared no expense on the cooling (the noise will be speed dependant, and those fans push serious air so high speed will not be needed.
Status
