I also use vacuum and brush without issue
.With a name like that im not sure your opinion counts here.
I don't use a hoover in my pc at all.
Never had anything bad happen to all the computers i have used the method i mentioned.
Just cleaned out my PC, took it outside and used a garden vac on blow to give it a good blast out. If your PC is neat and tidy inside anyway then nothing will get disconnected.
really
I use a vacum when cleaning my pc but i use a soft paint brush to loosen the dust and hold the vacum nozzle a couple of inches from the brush to extract .
