Because I'm on a budget, and trying to find a reasonable bike cheaply is hard work. Things can always be upgraded. No point getting cheaper wheel kit though as that's expensive to upgrade.
The most important feature of the bike, the brakes, can't be upgraded, the frame needs a built in adapter to fit a disk brake caliper.
Also, I'm unsure about how I ensure I get a back wheel that works correctly with my mech.
Do you ever get wheel spin on these things on the wet?
I'll be replacing my Cyclotricity 500 watt rear wheel soon on my spare bike with a 250 watt front wheel because I have no interest in doing 24 mph with a rear wheel that weighs a ton and eats the battery.
My Cyclotricity Stealth weighs 25kg where my Trek 7.5FX weighs 16Kg.
I'm actually going to transfer all the electrics on the Stealth over to a Carrera Subway and have that as my spare bike.
If you have a front motor you won't have to worry about your gears and to be honest you won't see/feel much difference between rear & front motors.
Thanks for your reply.
I'll look into a front wheel instead then, do you have any recommended brands/websites? I'm not interested in speed, being able to keep a steady 15mph including uphill is want (I'll still pedal on the flats).
Just looked into Cyclotricity and found their front wheel 250 kit - http://cyclotricity.com/kit-configurator/?xt=5&xp=&xm=4
Seems I'm loking at about 450 quid - only two months worth of train fair so if its a decent kit it will be worth it! Are they easy to setup?
I'll go for whatever is cheaper (looks like a screen is an additional 80+).
Can you use these systems as pedal assist, or is it simply pedal or use the electric motor?
I spent Friday morning in A&E after a motorist pulled out on me but only ended up with cracked ribs.
My bike came off a bit worse though![]()
