Remote Access Software
28 Jun 2005
Hi. I'm looking to access my home servers remotely so I can play with them from work. I've got a few ESXI hosts running a mixture of Windows and Linux guests attached to my home network connected via BT infinity. I've got a Win 2012 DC that I was thinking as a likely candidate to install some remote access software on and then SSH around from there. What do you guys for this? Thanks
I set up the VPN through my router (Asus RT-N66U) so I'm not too sure on that part as I'd imagine you'll have a different setup. But once that is done then the rest should be fairly easy, you can use remote desktop connection as if you were on the local network.
Fast and simple setup - teamviewer
+1 for this good reliable and simple. its not perfect but i find it hard to fault tbh
other wise from a learning expirence i would suggest : what andy_mk3 said :
Can you not use RDS through a VPN? That's how I do it.
you'll learn a few extra things in the process.
depening on your position at work though you may need to have Ports open to allow the vpn connection and i guess your on static ip at home?
I don't have a static IP so use DDNS, and have never needed to open up any ports.
Where did you get that from? Teamviewer is free for personal, non-commercial, use which you imply in the OP this is because they are (a) at home and (b) you are "playing" with them.
Exactly the setup I use. Teamviewer in a personal form for connecting to home PCs and ESX clients running on my little microserver.
Use SSTP, runs over 443 and built in to RRAS.
Bit puzzled by TeamViewer. It's installed on a 2012 DC and set up for unattended access and is installed as a service. I cannot get the TeamViewer client on my PC to connect to the VM without also being RDP'd onto the VM and the screen not being minimised.
The message I get is:
"The screen cannot be captured at the moment. This is probably due to fast user switching or a disconnect/minimized Remote Desktop session".
As soon as I disconnect, log off or minimize the RDP session to the VM, TeamViewer locks up with the above message until I unminimize the RDP session?
