Seeing OCUK's prices creep up day by day has put me off buying from them entirely. I've seen the SC ACX 2.0 for a full £85 cheaper elsewhere.
I'm out for now. Will check other retailers in a few weeks when everyone has stock.
But at what resolution!?
Card will be here between 4pm-5pm..almost every other DPD delivery comes before 12pm, why does this have to be so late![]()
Track your delivery, dpd give you a little map showing you where the driver is. Go find him and get it![]()
..tempting though..Surely this must be 1080p. I am getting 70+ fps as well with everything maxed out but that is with 2x 980 Ti's at 1440p. Single card gives 50+ fps.
WHat sort of 24/7 clocks and bench clocks are people seeing?
1000@1250Mhz base clock gpu OC (max boost 1465Mhz). 1753@1945Mhz vram OC. Those are both my 24/7 and bench clocks![]()
Running a custom bios? I think my reference MSI boosts to 1160 so I'm thinking about flashing.What temps are people getting with the EVGA SC ACX doing normal desktop work Internet browsing? .. Is it creeping up to 60 to kick the fans in? I don't like it so set a custom fan curve up
