I recently moved house and bought some cheap table (previous one was a decent £200 corner desk from Argos that lasted about 6 years but decided not to bring it with me).
The current table was purely a temporary table until I settled down to get a decent one, so that time has some.
I've been looking in the desk and room gallery and found a few that look great
http://forums.overclockers.co.uk/showpost.php?p=27998962&postcount=759
http://forums.overclockers.co.uk/showpost.php?p=27721045&postcount=651
As such, I've found the alex range on ikea (http://www.ikea.com/gb/en/catalog/products/10192824/) unfortunately I can't find the one that comes with the filing cabinet but I can live without that..
So the following is my current cart, can anyone recommend anything I'm missing and a table top that'll fit that (fyi everything else in the living room is wooden laminate flooring, white walls, and oak effect tables/tv unit/etc.)
2x ALEX Drawer Unit (White)
1x SIGNUM Cable trunking horizontal, silver
1x FIXA 114-piece cable management set
Have never bought table like this (typically buy a full thing, rather than bits), so will I need to screw the top into the drawers or get other legs for it or something? don't really think it'll just 'sit on the top' fine.
Suggestions?
Suggestions?
