***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Anyone had any experience with Grizwald's juice? I tried their Caramel Cappuccino which is very tasty but quite pricey.
I came across a FB group called Morton's Mix. Anyone used them before?
I have just put a couple of claptons in the plume veil at .4 ohm and its firing great up to 50 watts, i love the plume veil but i would love it even more if it didn't leak so much.
picked up a few juices at the local shop, 2 custard based a dutch apple and one with anise in that im not entirely sure about. one of the custard based ones is a njoy artists PARAMOR and while it is pleasant enough i don't get enough of the fruit in it to really set it apart, maybe i just need to find the coil and wattage for it.
cyclops custard is just that, a custard so nice enough.
mr goodvapes dabbledooya, i get no dutch apple and no cinnamon so just lots of vanilla and cream, bit of a disappointment.
bordo2 dopamine. I want to hate it so much, too much menthol, the anise that the vendor said was barely there is smack bang behind the menthol and both do a fantastic job of blocking out the blueberry. I don't hate the flavor i just think it is meh. If it mellows and blueberry shines through then i could see it being a fantastic vape. i may dilute it a bit and add in some blueberry to make it what i expected of it.
I also ordered £50 worth of mixing supplies to make up a decent batch of custard and a mothers milk clone, i should have more than enough fruits and creams to have a go at some other smaller batches also.
Grizwald's stuff was my go-to for quite a while. Arctic Pipe in particular... though it seemed to tie in with giving me really awful acne, and the same happened to a friend of mine who loved it as well. We both gave it up in the end.
Subtank RBA has killed itself somehow.
Tank had been sat in the box with the RBA Base in it since yesterday as I'd been using the Lemo2.
Put the subtank on to my mod and it was reading no atomiser, stuck it on my ohm meter and couldn't get a reading from that either, it's fine with either of the OCC coils though
Check the insulator hasn't melted... :)
the HCigar VT is now in stock and it feels quailty
Mark Todd said:
Feels like it's made by the same people as the sx mini
I don't need another mod... and I've spent £200 pounds on two atties this weekend.. sad times... :'(
Any suggestions for a new mod? I've been waiting for the Sigelei 75W that's due out later this week but am a little wary of having to replace it for something stronger a few months down the line, seems every time i buy a new tank i need a better mod. Don't really want to spend more than £100 on it.
I'm also after a couple of tanks. I'm picking up a Freemax Starre as it seems to get good reviews and can use a few other companies coils but fancy something else to play with too. Any suggestions for the second one? Nothing tiny that needs filled every 5mins.
It depends what your after? if it's raw power; you can't go wrong with the snow wolf (150w + 50w pwm) .. I think the chip comes from the same company that made the chips in the dolphin and invader..
http://innovapours.co.uk/index.php?route=product/product&product_id=584
I highly rate the yihi sx minis (60w)... and the h cigar VT-40 (40w) looks good for the price.
Same with tanks, depends if you want MTL... Direct Lung or/and sub-ohming tanks. :)
The sx mini is out of my price range at £170 and the hcigar only being 40w seems like i'd be better off with the sigelei 75w, it does look nice though.
That VT40 is a handsome device. Is the DNA board upgradeable on it?
nope... only the new 200w dna chips are, but it's the latest one with atty lock so the temp control will work better that the prevous versions.
what sort of power are you after? :)
Honestly i've no idea. I had planned on the sigelei but thought i would ask if there was anything else better out there under £100. Just trying not to get caught in the never ending buying cycle every time tanks change.
I tend to have two vape modes... normal.. MTL where a vape at 14-17w and then I have my crazy sub-ohm mode which I vape around 25-35w. :D
I've never needed to vape anything more, so 60w is more than enough headroom for me. I do know some people vape around 100w and so forth but each to their own. :)
When anyone first start they buy everythinig like crazy.. but you do settle down once you know what you like and what you don't... it takes some longer than others, and cost some more than others.
I have over 10 mods.. but I know for a fact that some have people have more. no more mods for me now; no more tanks after the two I've ordered have come... next month is dripper month and that's it. :)
Today I've accidentally concluded I prefer slightly higher resistance coils to sub-ohm
Rushing around to build oil for my Lemo2 this morning and ended up picking up the wrong gauge wire and miscounting the wraps but threw it on and stuck it on my meter and it came out at 1ohm, so quite a bit higher than the 0.5ohm I'd been vaping it at. As far as wattage I'm vaping this at the Same 35w as the 0.5ohm coil and what a difference, flavour to me is smoother and more pronounced.
Status
