More maintenance:
Looks like it will be down until 7pm
Bungie really need to sort their maintenance schedule out. Far too much disruption.Why cant they have an in-game announcement?
ps3ud0![]()
Sorry I know they do it when you are in orbit, but not when you are on the surface, which its going to be most of the time. Just something that should exist considering how often we get 'kicked' posts in here. At least an in-game warning of say 30mins would let most finish what they were doing...Well to be fair when I logged in, it did come up with a message that destiny will reboot at some point. Would be better if they gave a time etc.
1.2.0.4 - The one about Passage Coins and Demo weapons
This update to Destiny makes two small adjustments to the way Passage Coins are distributed in Trials of Osiris and how weapons behave as players migrate from the Destiny Demo to the full version of the game. Pardon our dust!
Weapons
Adjusted the 402 Attack Rating for weapons acquired in the Destiny Demo down to the proper value of 365
Trials of Osiris
Removed Passage Coins from the Lighthouse reward chest
Added a chance for Passage Coins to be awarded after match losses
ps3ud0![]()
not that the place I bought it from can do anything, told me to wait 2 weeks.Out of curiosity, what sensitivity do people use?
I had mine on default since launch, but recently upped it a few notches. Seems to have improved my game a bit. The aim assist really favours a higher sens I feel.
While I don't personally have an issue with it being random, I do feel it actually goes against the way the rest of the raid is set up....
Opening the door - you split into teams of your choosing to open the portals and keep them open.
Defending the confluxes - you split into teams of your choosing to defend the conflux
Destroy the oracles - you split into teams of your choosing to cover each area effectively
Defeating the Templar - you pick a relic holder and work as a team to defeat the Templar
Defeating the Gatekeepers - you split into groups of your choosing to open portals, enter the portals, destroy the Gatekeepers and then pick up the relic
Defeat Atheon - you don't get to choose a thing, it's virtually all random except for which one of 3 random players will pick up the relic, assuming one of you even wants the job
That's the only issue I have with it. The rest of the raid teaches you to pick a role and to learn that role, yet the final part of it goes against the grain and makes it all random.
Who said anything about them changing things? What I was getting at was that the game could have been so much more then just grinding the same bounties daily and the same nightfalls/raids once a week. What I mentioned was just an example and would have worked fine for both PvE and PvP types of players due to the way you're matched together on Patrol in the first place, all it would need is an option to disable PvP before you start match making for patrol which is all it is, it's not like it's a giant dedicated world/server where everyone plays together. Depending on who has it enabled or disabled you would then be matched into the correct lobby.
Thing is though, in Destiny all players are on the same side. Having PvP outside of the Crucible makes no sense, it doesn't fit in the world at all.
Ah, the weapon balancing! So your proposed solution is to completely ignore the game data telling them that the vast majority of weapons were being ignored because ARs were overpowered? In what world is that going to make the game better?
You need etheric light to upgrade your armor / weapons to the max level
You get this from doing the level 34 or level 35 prison of elders / nightfalls / trials of osiris (ultra high end PVP 3v3 competition) or from iron banner. You can help yourself get to level 34 by doing the level 32 prison of elders which rewards you with a level 34 piece of armor.
Iron banner isn't on now so your best source is to do Prison of Elders. what level are your characters ?
I usually play on 7 but recently dropped it down to 5 as I found it was taking me a split second longer to aim when going ADS with scout and sniper rifles. I'm going to up it to 6 though as I find the turning time (going round corners etc) is too long on the lower sensitivity.
My proposed solution is to stop meddling and changing things for changing's sake.
You will never stop one type of weapon being used more than the others. All we've done is swap auto rifles for hand cannons.
Guaranteed the next step of patches will just change it again. The community will always take the path of least resistance and find the best class and then everybody will flock to it.
