The Fury(X) Fiji Owners Thread
I don't know what it is with Anand, i havent trusted thier reviews for some time, if you replicate their AMD benchmarks consistently they are way under.
Issues all over the reviews.
amd needed to make sure 4k was the only resolution tested as the card is built for it. they didnt. I can read one review and its a win for one vs the other.
next its all swapped.:rolleyes:
Its like they get the result and then calculate it 15% less and publish
As with most review sites, they're only good when it suits.
That's why owner feedback tends to be a lot more accurate.(IMO)
Not a dig by the way. :)
A lot of the Fury-X reviews don't suit, i have used them to be critical of the GPU.
I have a 290, ANAND's reviews don't sit right with me :)
Finally managed to get a pic done
Here is mine sat in front of Titan ReX
Will start testing tomorrow.:)
Thanks bud,
I'll see if AMDMatt can assist first then try emailing :) just a pain, it's like the monitor knocks off for a split second, only at 60hz, 30hz its fine.
Hey Reece,
Drop me a trust bud with all the details.
Gpu, monitor, firmware, driver used, os, cable used etc and I'll investigate. :)
Which reviews are correct then, the 100s where it's slower or the 2 where it's faster?
Cannot wait - get to see some benchys - will you bench all for to get the single best clocker and then use that in you're tests for the benchmarks or just jump in and get bench-marking on 4xcrossfire ? :)
both.
I said it before, valid comparisons cant be done by review sites and personally I think they played out their roles.This era I would have if I was at amd used a whole new way to review such.
Its social media for a reason.
I think its fair to say there's plenty of reviews showing it trading blows with the ti and tx, Also quite a few showing it to be lagging behind them slightly.
