Yep. That was the last thing I tried but I'm up to date. Am sending it back first thing Monday.
By the way, the old ram in there had a speed of 1066mhz. The new stuff is 1866mhz. Does that matter re compatibility?
Easy installation and automatic overclocking; no adjustments in BIOS needed
For some reason I can't change the memory setting in BIOS. The option just isn't there.
Maybe that's because I shouldn't have anything over 1066mhz in there???
I noticed this on Kingstons page
http://www.kingston.com/en/hyperx/memory/impact
If you can overclock, can you 'underclock' ram?
Then again, even if so, I seemingly can't doing anything at all with it in bios.
I'm screwed, aren't I?
