Which 980ti for watercooling
6 Mar 2010
I'm thinking of upgrading from 7970cf to a single 980ti. The card will eventually watercooled. Am I best off just getting a reference board and o/c it, or getting a pre-over clocked one?
Get a reference card, flash the BIOS and install whichever Titan X block you like the look of :) For choosing a brand, most people seem to get on EVGAs bandwagon but in reality most of the major brands are fine with removing the block as long as you don't go gouging holes in the card trying to get it apart
Cheers guys, was thinking along those lines. Will prob get the Zotac reference that's on offer this week for the 5 year warranty.
Zotac sounds very strict with cooler removal and it states on their website that removing cooler voids warranty so i wouldnt go with them. Grab a OCUK one.
Silly question but do you have a link to that as I have been looking for that info for a while and haven't been able to find it, which is why I posted in the thread linked above asking if anyone knew Zotac's stance on cooler removal to add a waterblock.
If your that concerned then get the EVGA one as they allow cooler removal and the fitting of waterblocks just remember to keep ahold of the hsf as it must be returned with the card for rma purposes.
I spoke with the sales team yesterday and they said it was fine to swap the cooler on the ocuk ones, as long as it was replaced before any returns (and wasn't damaged as a result of the removal process).
Why would they tell me otherwise then??
"Thank you for your webnote.
Removing the cooler would void the warranty on the card I'm afraid.
Regards,
Simon Bagshaw"
Appologies if im not aloud to put the guys name but will be pretty miffed if he not told the truth as i wouldnt have paid the extra £150, someone from OCUK confirm this?
Shame you can't buy GPUs with no coolers (like the Intel recent chips that come with none) and then fit your own.
I guess they would be worried about people blowing them up though :p
