Caporegime
- 18 Oct 2002
Amd need to step it up on getting more performance from the driver's, and the sooner that there's some voltage controls for the core the better. It has a lot of cooling headroom so hopefully more performance under the hood.
Agreed. It also makes me wonder about the Fury cards and what clock speeds they'll come out at. If the best they can get is 1050Mhz on a very good CLC then what are they going to get on air!?? It's obvious that they pushed Fury X riiiiight to the limit with that clockspeed.
I'm guessing around 950/975Mhz with the normal Fury cards on air, which combined with the shader cut will pit it between the 980 and Ti...
