The GTX 980 Ti owners thread.
I was on 352.86...so i guess that didnt support 980ti..so that might have been part of the problem.
gonna game for a bit on bf4 now and see what happens.
already ran it for a bit and its pretty impressive!
I think the first drivers supporting it were 353.xx i know it was around the same time as heroes of the storm optimised drivers
31st of may if i remember rightly but am out and about at the mo
I think my temps of the CPU are higher with the msi gaming. When I game they hover around 61 on the old blowers...with this card they are up to 70!
Non ref cards will up cpu temps a bit. Found this with wf 780 sli. 72c on the msi is good, going by reviews its pretty much round this area. Nice boost speed too.
suprised it was agood 7 degrees.
Thought I might have damaged the cpu cooler (AIO) during the card swap..but i guess Id be seeing much higher temps if I hard knocked it and caused damage.
When I had the 780 setup, if I ran games without an fps limit. CPU temps got as high as 75c. With a limit of 60 set, cpu temps no higher than 65c. Also the gpu's ran in the mid 40's as opposed to 76 and 65c. CPU is clocked at 4.7ghz on air cooling on 1.300v.
I would have thought the opposite, what makes non ref cards do this? In my experience with AMD the reference ones were like ovens!
non ref seem to dump heat out the side of the cards, and therefore into the case.
ref blowers dump the heat out of the back of panel of the gfx card.
I expected trhe temps to increase...but not by so much!
Non ref cards dump hot air into the case. Whereas a reference blower expels it via the pcie slot. An aftermarket cooled card will always run cooler than a reference model due to more fans but you do need much better case cooling to deal with the heat they add into the case. In my situation it was made worse by having two non ref cards.
project cars results are in.
Everything maxxed although only MSAA enabled, with rain enabled and I hit 73c with a boost of 1330. fps was around 80-90fps.
card is promising. plus no crashes yet using the latest released version.
not sure why it didnt boost to 1370 like it did in bf4. will try some mild OC later.
Everything maxxed although only MSAA enabled, with rain enabled and I hit 73c with a boost of 1330. fps was around 80fps.
Any overclocking yet? Getting the same card on Monday.
