Kaaps here's mine for the ROH.
Hi Soldier
would have happened to installed your Fury x yet, I was just wondering If you have had coil whine issue?
Would seem they is some gain to be had here..
Here is just from 500 to 550 and got extra 173..
http://forums.overclockers.co.uk/showpost.php?p=28248226&postcount=1957
so;
you that would be ok would it!
"Capacitor Squeal is actually the noise heard when a capacitor is about to fail. Essentially it’s where gas is escaping through tiny holes in the capacitor and makes a “whistle” sound. You can usually visually spot this simply by looking at the top of the capacitor that’s making the noise – if bulging or you can see a brown fluid then this is a true capacitor squeal."
Fury X installed. Still can't run 120Hz without flickering but not a biggie and I will get something sorted.
Time to play
Ohhh and no whine, which is a massive phew.
Time to play
I am not a mod, but you guys shouldn't be talking about selling stuff outside of the members market. Don't get yourself suspended for something silly.
Personally, I am very excited about this card, and really hope to get one like you guys![]()
First I have to say I'm jealous that you got a "good one" and so even more gutted that mine was faulty. Anyway, congrats Greg and enjoy
What screen are you using by the way, I had no problem running mine in 120hz or even 144hz with my Asus MG279Q.
The flicker issue Greg is having seems to be a compatibility issues with the Gsync monitor he using and amd GPUs..
Wrong, no flicker and running 120hz here
Yes mate.
Not noticed any ill effects as yet
Someone who knows what is what recommend me a lead please (needs to be 3 meters). Having a complete nightmare and oddly enough, not with the GPU but this capture card. I can only capture 1080P or 4K and nothing in between arghhhhhhhh
Ok I have always thought this display didn't work correct with AMD.. Leave me scratching my head has to why Greg monitor will work with Nvidia and not AMD @120/144
A fault with his display or something he doing wrong maybe?
Nope coil whine in this case means that a component (containing a coil) is being provided power / signal at a frequency that causes it to start it vibrating at a very high speed, in turn this crates a high pitched noise (known as coil while). In this case the whine will probably come from the chokes, these are used commonly to block high frequencies.
