***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Ah yes it is.
So another question why is it 4.2v when the batteries are 3.7v?
So with my Parralel box I need to build around 0.1-0.15 ohms to be chucking dem cloudz
now to get some more batteries, fed up of waiting for these 2 to charge
Is there anything wrong with running a tank on a mech? never done it so just curious as 4.2v is what i vape at on my sigelei
I run some of my tanks on my mech mod(Dino Big Brother 2 x 26650's in parralel)
Just do your maths beforehand.
.25 ohms build in Zephyrus is about 70 watts with freshly charged batteries.
1.8 ohms Mini Nautilus is about 9.8 watts , batteries should last a while :D
My Vamo v5 is dying a slow death and needs to be replaced.
I have some 18650 batteries and an i4 charger I can use.
What are my best options as a replacement? The batteries don't need to be reused, just an option.
I use an aspire nautilus
wow mister, you do have expensive taste.. Todd was looking for one of them drippers a few weeks back, I'm not sure if he manage to get one thou.
In other news, I've just sign up for a HEM account... even thou I am poor; or soon will be. I'm also in discussions with c9v about the 510 pin on my squape as it's very loose and spinning when being attached on to mods. It's a shame as it's a great mod.
I would say Good taste and I don't buy often ;)
Triple coiled & wicked @ .6 Ohm and she's a keeper. Top quality & looks cool too.
Not sure on the Snake oil though!!!
HEM account:eek: dabbling in stocks or am I barking up the wrong tree?
Hi mate, the chances are that your batteries will be the older style cobat batteries that should not be used in the newer mods as it handle the amps. If you have a look at the first page there's some recommendations on the first post. If you have anymore queries, fire away.
HEM; High End Mods... :) or is it HEMO; High End Mods Org? lol Can't afford anything, just looking.. ;)
Sub Box Mini kit delivered this morning in white (don't judge). Really enjoying it so far. This is my first toe-dip into sub-ohm. Anything I should be aware of apart from avoiding blowing my face off?
I like the white subtank looks... if it's working than you must be doing it right, nothing really to look out for as long as you have a good battery and know how to spot for the signs of danger.
I got some Cotton Bacon, its alright, my initial hype of it has dropped a bit, still prefer my Jap pads tbh. Though the CB is super easy to work with.
You have a UTA don't you Balky? If so stick with the pads, CB doesn't do so well in the UTA's (IMO)
I don't get the hype with all the different types of cotton, I notice no real difference between a lot of them.
Sure between silica/mesh/cotton and the different types of atties to correctly use them, but I honestly notice no different between organic cotton balls and jap cotton! :p
Wonder if silk would work?
Never heard of it being tried, might look into it but I can't see it working, does silk absorb?
Yea I have a UTA. Pads seem to be the one, easy to fill massive gaps effectively.
How do you wick your UTA? I use the slots. From coil I go out through bottom slot and back into the chamber through top slot. Trimming the cotton out the top of the chamber and tucking it back in.
No I tend to agree. Think a lot of it is in peoples heads. However, working with different cottons is the biggest difference. Using pads and cutting strips, I find at least, so much easier.
Like this. :)
OK! Just re wicked my UTA 1, heres how I do it. This is the method I always use and have had all sorts of juice though it, from 50/50 to max VG. No leaks, gurgling, dry hits or flooding. :cool:
The reason I do it like this is because I learned the hard way when I filled it back when I first got it. I must have somehow moved the wicks while screwing the tank back on after refilling it, obviously moving the wicks and creating a 'hole' in the chamber, thus juice poured out of the air hole..... :embarrassed:
So now I do it like this and its been spot on each and every time.
FWIW, I always use the big slot, coil is .35mm, 3mm diameter, 6 or 7 wraps = ~1-1.2 Ω.
...and heres the UTA2 wicked the same way after a tank full has been though it. :)
Silica and Ecowool, I remember using them both way back when I first started rebuilding, Horrible.
Cotton or GTFO.
Well the Kanger Subox kit is being sent back and exchanged for another Nautilus Mini but with UKecigstore's one mod box.
Very good of them to do the exchange and they seem to have a very large choice of juice's.
Status
