With new drivers i would't ask "what resolution" as you can use DSR and game at 1440 or 2160p on the 1080 display...i do it usually but thats just my opinion.
It's not like DSR gives you the same quality of native 1440p or above
I fail to see why anyone would got for this considering it even has a waterloop. If the performance was much higher then yes, but a waterloop to get 980ti performance or even TX performance? I wouldn't bother. Also more moving parts to go wrong and possible reliability issues - I really wouldn't want any addition risk from water unless the performance was really worth it.
Just my opinion though![]()
Who put 10p in you?![]()
It's not like DSR gives you the same quality of native 1440p or above![]()
Currently 1080p with a second 1080p screen usually just monitoring stuff. Always looking for what to move to next but for the moment its 1080. 980 is better for 1080 im led to believe but originally my budget was (and still should be £400 i do regret not buying the 295x2 in clearance last week) £500 would be silly money for me to spend and above that is a no no.
