Most of all, the Amp! Extreme has a beautiful "unique" backplate:
** No hotlinked images please **
Always hitting the voltage limit on my MSI 6g. Is that normal?
+120 on core giving me 1450 boost.
Power limit is 0.
I really want another one, they would just look so good in my case![]()
Why is technology so expensive!
? Set the power limit as high as you can, that's the first thing to do before starting to overclock.
Yes. That is the first thing I've done, set to max 109. No issue with powerlimit, MSI reads 0 for that all the time under stress.
Voltage limit hits 1 immediately though.
Wondering if that is normal
That's a 45mm difference mate, that's hardly insignificant; I would definitely measure it and make sure before proceeding.
Oops I meant 29.5! I think I should be ok
Are the chips on the Amp! Extreme binned? I might order mine today. I'm travellingso won't see it till the first of August![]()
That almost impossible, unless watercooled.Buy an 8+8pin card which removes tdp limit without eediting bios and keep that card cool! Below 62c at full load.
Hi guys
Looking for some advice. I'm looking to buy 2 980tis to run in sli. It will be on an matx board so the cards are going to be sandwiched together. Which cooler design would be best for this setup, would it be better to go with a reference design? I rally like the look of the MSI gaming but I suspect performance will be impacted with them so close together.
The Amp! Extreme looks like the one I'm going to order. The only thing stopping me from doing so right now is the fact that I'm away and not back until the 1st of August. How long is the period in which I can RMA if there is something wrong with the card when I get home? There is no one at home who can test it for me, just my brother to take delivery.
