Windows 10
I've noticed Windows 10 seems to launch programs faster than 8.1.
Windows Modern apps are much faster, but even older desktop ones load quicker.
My Surface Pro 3 was always a little slower than my i7 Desktop but on 10 it matches it.
I've got a favour to ask guys - It appears that getting the Windows 10 drivers from asus is harder than it appears - I've got an Asus Ranger board, and keep getting corrupted volumes. Has anyone already got in their posession (or able to download a clean version) of the following:
https://www.asus.com/support/Download/1/45/6/15/n1YzcJITwZrK4LaT/45/
Audio V6.0.1.7525 Win10(WHQL) SonicRadar2.1.24
If someone could upload it to mediafire or something, I'd be grateful for at least a day.
Have you tried...
http://maxedtech.com/asus-xonar-unified-drivers/
Works for my Xonar DGX in Windows 10, there are various installation options, I'm using the low DPC latency option (which has no tray icon).
Edit: sorry, misread your post, will leave link in case useful to others
Have you tried...
Thanks for that anyway mate - I'm planning on switching to Xonar after I've gotten a new set of speakers for my desktop
Urgh. I seem to be stuck.
My test VM won't sign in to Microsoft for insider builds, nor can I add any accounts local or otherwise. Everything just keeps telling me "Something went wrong". :(
As far as I am aware the Build 10162 shouldn't have any problem! Have you feedback it to Microsoft?
I'm stuck on 10158, I can't sign in to "Fix me" via Windows Updates as it just gives me the same error.
Oh and I can't send Windows Feedback because... yep you guessed it - "Something went wrong!" Actually, that's a lie it says "You'll need Internet for this" and doesn't think I'm connected to the Internet.
Actually, therein lies the problem I would imagine. Despite having connectivity I'm guessing there's something somewhere that isn't reporting me being online and that seems to be breaking user accounts. Which is daft when trying to add a local account. Dah.
I think your misunderstanding.
This doesn't mean the free upgrade from 7 or 8.1 will be available for 2 to 4 years, its saying that rather than releasing a paid for 10.1 or 11 like they would have previously, they will be releasing updates over time. From an accounting perspective they have to define what that timescale is so that they can defer the revenue over that period, as per the legislation around accounts. In order to do that they need to define what they consider the lifespan of the product to be, which they have set at 2 to 4 years depending on customer type.
So what this means is that if you buy retail Windows 10 for $200 and they define consumer life as 4 years, Microsoft books will not show $200 of revenue in 2015, but will instead show $50 in 2015 and the rest deferred, which will be recognised as $50 in each year 2016, 2017 and 2018. You can't recognise revenue for a product or service until you have delivered it. This practice means that Microsoft will not have 'delivered' all of Windows 10 until 2018.
Its a shift in their accounting practices to reflect the shift in the product. What it does mean for us though is that the upgrades and improvements Microsoft are delivering for free will come for at least as long as they define the lifetime of the product to be.
RTM isn't coming to the Fast ring until 29th.
What will happen is RTM will start being pre loaded onto those people's 7 and 8.1 machines where they have reserved an upgrade.
no the way i see it is it mean the upgrades of builds. it gives 2 or 4 years worth of upgrades to new builds etc.
For people using asus sound cards with windows 10 - I found this and worked perfectly with essence stx 2
1 - GO to asus support site
2 - Download the last driver for windows 8.1:
- For example STX_8_1_8_1822_Win8_1.rar
3 - extract files and go to "WIN81" folder
4 - looking for "CmSetx.dll" file, and edit with notepad
5 - The configuration file, has 4 lines:
[SETUP]
ATYPE=30
INI_PATH=SoftwareDriver\InI
SupportOS=win81
You need modify like this:
[SETUP]
ATYPE=30
SupportOS=donotcare
6 - save changes and run with administrator privileges "Setup.exe" of root driver package folder.
ps. Setup.exe from WIN81 folder not work.
[SETUP]
ATYPE=30
SupportOS=win81
[SETUP]
ATYPE=30
SupportOS=donotcare
would that work with onboard sound as well?
