Posty slightly later than norm but came today. Got my evod 2 kit.
Slightly heavier then pens are than what i imagined tbh. Tho as the saying goes the heavier then the better materials like metal instead of plastic in em so. Tried starting one of the batteries up with the 5 clicks, it flashed ok then i turned it off with 5 clicks so one works i guess, not tried the other yet.
I opened it up to check the cartridge thing and it looked different from what i thought it was going to be, as i expected to see some but not a lot of wick from the sides in the middle. Did a bit of googling and found i have the improved dual coil ones, so i guess cool on that score.
For ref, i thought i was getting middle one but got the left one.
I checked if it was genuine and yep it checked out.
Funny tho, i thought u scratch the panel off but it was already revealed and didnt look like they were suppose to have any scratch stuff over em. :/ Ah well, seems to be registered ok and was shrink wrapped.
One thing tho. I have a uk plug. To me the connector ends on the pins of the plug seem scratched up or somit and kinda looks like they were glued on or somit as if u touch the pin and around it, it feels like hardened glue or could just be the plastic or whatever and just be me. Ill post a pic of it at some point to see what u ppl think if i should use it cos i dont think i should and hope usb chargin is enough.
Juices didnt arrive today tho.
The site said they didnt ship my juices even tho was before 3pm on tue like the evod2 because they had a router issue. Grr.. Would have been nice if they had bumped up the shipping to next day for me cos of their error.
I could go up the shop they have some ejuice but i dunno what it would be like, there in dark i think black boxes, about 2.99 i think and looks like theres about 40 diff ones and they are next to mini ecig refills the orange ends for the replicator cigs. But meh i think ill just wait till tomorrow.
Just tried usb charging it, both batteries stayed green. Presume they were connected ok i did tighten them up to finger tight as i could, didnt wana push the last bit tho. I screwed em in so far then the battery led flashed a few times then i screwed in a bit more as i said up to about finger tight but yeah still green led on the usb charger so i presume there both fully charged still. Not bad considering that u usually have some drainage from batteries when bought. Maybe the off feature makes it so they dont drain or somit or very little compared to turned on state.
If it works as well as i hope it does after i manage to get the ejuice tomorrow, then for £25 for the evod 2 aint a bad price and genuine too.
Payes to search around for best price sometimes.
