What fan is that? Is it just powered from the drive bay?
My E3-1265 hasn't needed anything yet but that might change in the heat wave.
Installed a 5th hard drive in the n54L today, and it has become so noisy!
Any suggestions how I can stop the vibrations, it is in the study and driving me mad. If I apply pressure to the top it stops.
This is caused by not having enough RAM. ESXi requires 4GB minimum. The NIC error does throw you off somewhat. I think it basically has insufficient RAM to load the network stack.Anyone had any issues installing ESXi 6 on the Gen8 Microserver?
I've tried both the standard and HP's customised images (from here: http://www8.hp.com/us/en/products/servers/solutions.html?compURI=1499005#tab=TAB4 ) , both of them fail installation with an error about not detecting the nics.
I use the HP customised one on mine which gives you better hardware monitoring.
You need the latest BIOS. There was a bug in the on-board NIC firmware that causes the install of 2012 R2 to hang.Anyone got an idea on this?
I'm trying to install Server 2012 R2 Essentials on an N54L and can't get passed the install bit as it states it is missing a driver. I've removed my Intel NIC and returned to onboard but get the same issue.
I've also gone to HP's website and downloaded the driver for the onboard NIC and correct OS but it's been trying to install it for the past hour so it's not looking good.
My BIOS is a 2011 version do i need to update this, if so does anyone have a link to it?
When you say it's telling you it needs a driver... What do you mean? The only issue with the G7 was that the 2012 R2 install would hang until you updated the NIC's firmware (via the BIOS update). This is the latest version: 2013.10.01 (A) 15 Nov 2013
Once the BIOS is updated, the install proceeds without problem.
I've never installed Windows Essentials, so it may be different. If it allows you to provide a driver, download this one and unzip it to a USB stick:
http://h20564.www2.hp.com/hpsc/swd/...=MTX_138a4027261540ee83265cf73e&swEnvOid=4139
