Struggling to find consistency in my aim, I just seem to go from being able to top frag one map to bottom fragging hard on the next
Just remember your core fundamentals when you are playing against better Aimers than you.
Just make sure you hold your angles, prefire common spots, check corners, use Nades effectively and always work kills of a team mate (I.e. Refrag), super important for T. Don't take risky engagements as CT.
When you're having a bad game or the other team has better aim that's when you're core fundementals are the most Important.
Good advice here, also work in pairs whenever possible.
yeh got a sneaky into navi when game was still open at 4-0 for navi. C9 destroyed on inferno so should be easy money
Quoting this in case C9 win overpass
Was a bit 2 close for comfort in the end![]()
