Vape Expo was nothing on Vape Jam UK. I actually didn't manage to walk away with ANY free juice from the Expo. Vape Jam, I had about 120ml.
Actually, I did get the free 10ml bottle that was handed out on entry. 0mg nicotine; cheers for that, like.
Where did people manage to bag free bottles?
As an aside, here's a question:
Picked up an RDA for use at home. My mod is the Cloupor Mini (30w).
At the moment, I'm using the RDA with a 1.6ohm dual coil (32AWG) at 29.5 watts. It's good, but I also have some 26AWG wire here, which I built a 0.5ohm dual with earlier today. Problem was that the coils heated up too slowly, and caused the mod to get very hot in the hand, at 30w.
I assume, to get that wire firing nicely, I'm going to want to hit it with 45-50w -- BUT the Cloupor also has a VV mode (up to 7 volts). If I rebuild at 0.5 with the 26 (dual coil), and switch the Cloupor to VV mode, pump it to 5 volts... will it fire? Because that would be the equivalent of 50 watts on VW setting.
Or would the Cloupor refuse to do that because it's going to be over the 30w limit?
Which gauge wire are folks here using for low ohm builds? I'm talking 0.5-1.0 ohm (I don't do lower).
