Arrested for ''abstracting electricity''
No the pcso on a power trip called them. Pcso might actually slowly take away work from actual police officers
Or the PCSO called them because he was dealing with someone who was not obeying the rules, was rude and became aggressive?
I love the way it's automatically the PCSO at fault when it's some idiot who can't read (or thought he was too important to follow the sign-age) who created the problem and by the looks of it continued to create a problem.
I suspect the "artist" would not have been amuse, (and would probably be claiming compensation and asking "why wasn't I told not to use my phone charger in this socket" if a surge killed his phone.
[TW]Fox;28312229 said:
I don't think you realise the difference between the requirements and amenities offered on long distance Intercity trains and the requirements and amenities on short distance urban commuter trains, hence the bizarre and meaningless comparison an a London Overground commuter train and a Virgin Intercity service from one end of the country to the other, as if the features on one should automatically be present on the other simply because they both happen to be 'a train'.
Aye, aren't the local commuter trains often some of the oldest rolling stock in the country exactly because they're not expected to have people in them for long, or at speed and hence don't have the same level of comfort etc.
So a modern train might have a fair amount of power regulation because besides anything else, they tend to have a number of sensitive devices on board as part of the train equipment (electronic signs & announcers, wifi hot spots, CCTV), whilst the older ones were designed to basically have lighting.
I wouldn't plug an expensive device into a supply that I could see was unstable, or was aware was likely to be unstable (I remember some of the old carriages that ran on my local line, the lights flickered going over some points etc).
Up here in the countryside I stick my laptop into First Transpennine trains, they keep running too and the train does not explode or anything.
Bit of a non story really, the guy was probably being a butt-head about it.
That said, I've been on trains that have mains sockets on the table tops blatantly for people to charge phones/laptops etc. So I can understand why he thought it was ok, but when asked not to use it, he kicked off, I guess that's where the issue lies.
Silly thing is it's not like its costing the train co. anything in real terms.
I plug stuff in all the time when out and about, but I ask politely first, and have never been turned down...
Idiot plus jobsworth equals news story I guess.
Do you not have fuses in the plugs for your 'expensive' devices? :cool:
Normal fuses in plugs tend to be relatively slow acting*, and from what I understand the train in motion can (if the carriage itself hasn't got filtering to the sockets) send surges through the socket as the power pick up passes over joints in the supply rail or cabling. They do little against momentary surges of the sort you get in such situations if my memory serves.
Of course the charger is more likely to be damaged than the phone, if properly designed and it meets the safety standards.
But the main reason I wouldn't plug a mobile phone into a socket marked "for cleaners use only" or similar is that I don't think the rules don't apply to me, and I have what sometimes seems to be an unusual ability to keep on breathing, thinking and coping without a mobile phone in my hand constantly.
Which tends to mean if the phone runs out of juice, or runs low I'm not desperately looking round for somewhere to plug my hand held tasp in to be recharged.
I've never grasped how/why people get so addicted to their mobiles that they can't put the things down for a few minutes when the situation is inappropriate for their use, and seem to panic when they run out of charge.
*They're intended to cope with things like the momentary surge when you turn on an older style electric motor without blowing (such as your vacuum cleaner, or freezer) and from memory are more current related, not necessarily voltage (or at least not low and quick enough to stop the over voltage damaging something else). One of the reasons a lot of devices may also have an internal "fast blow" fuse, as the plug fuse may not blow fast enough to protect internal components in the event of a fault.
The moral of this story is he should have bought the same phone as me, 4 day battery life and does the same as his iPhone does, problem solved.
Also, charge it overnight, I presume he lives in a house with electricity?
