Corsair preparing 350d and 750d meshed plates
Yeah it is a real pain. All of this could have been avoided if there was a pre-order option, less hassle for the customer, likely more completed sales in the long run.
Slightly off topic I guess? BUT :D I have the Corsair 450D I broke the little plastic connections on my front panel whilst being heavy handed whilst it still attaches I was wondering if a 750D front panel would fit since looking at the images it just appears to have more drive bays adding to the length.
I'm willing to sacrifice some airflow for looks as my temps are low as it is.
Off hand I don't know, I'm doubtful it will fit but if you want to do some measurements I'll be happy to do the same with my 750D for you.
That would be great.
33cm x 18cm if the cheapo measuring tape toy which looks like it came from a Christmas cracker is accurate :p :rolleyes:
35.1cm x 20.1cm. So doesn't look like it will fit.
Can you re-measure it until you bring me good news? :p
Jokes aside thank you very much I appreciate it.
Will dig out a proper tape measure from the shed tomorrow to double check my measurements but nevermind.
Ordered !!!!!! £16.06 in total i presume its being shipped from within the uk and not usa.
i just hope my order is back ordered and i have to wait for the next shipment of panels to come in to the uk .
Happy to help, hope they have enough stock.
Would imagine it would be shipped from the EU hub, but that is just a guess.
Just ordered mine, been checking daily for the last two weeks. Sods law that the day I don't check the website is the day they get them in stock. Hopefully they still have stock and that I'm not too late with my order.
replacement arrived today greybeard. Just to let you know it seems all fine - much better as it doesn't bend at the top.
Was there supposed to be an additional filter with it as someone else here mentioned?
thanks for your assistance btw dude - appreciated.
Got mine on Wednesday, shipped from Netherlands. I think i've got a couple of degrees drop in coolant temp but it's hard to say, I'm not that fussed anyway. It looks nicer than than the solid front i think.
