Permabanned
- 12 Sep 2013
- Knowhere
This is also my recommendation. Or look for a used 290 too. Basically the same card as the 290X and you might get lucky on one.
No no and no, A 290 is not basically a 290x, Just like a 390 is not a 390x and a Fury is not a Fury x. They may sometimes have very close performance figures but there are often times when there can be quite a gap between them.
If you want to ensure the best one all the time then get the better version but if you want to save what can sometimes be a decent chunk of money and you don't care about some titles being a fair few frames behind as long as it is still playable then go for the cheaper card.
Personally I would not buy secondhand as you do not know the history such as how extreme and for how long overclocks have been used with the card.
At the moment I think the 970 is the bargain 1080p card, The 390 is the bargain 1440p card and if you just want grunt regardless of cost the Ti is king. 980 prices are looking quite good if you go for something like an Inno3d x3 and it would be a great mid range option for both res's.
