SR20DET?
+1
Edit:
Or 2JZ like someone else mentioned.
But please don't do an LS swap...
SR20DET?
Sounds epic in a weird way... you'd certainly fear it!
how about 4 rotors...
https://youtu.be/Bzi2_oiBMmY
The best rotary sound in the world. This is even better than the Furai imo.
Rebuild it, you're clearly attached to it so logic doesn't come into it. I still miss mine, they get under your skin in a way that other, less explodey cars don't.
Awesome, I assume you went for a rebuild? If you don't mind sharing roughly the cost on a rebuild on one of these. I've had a big soft spot for these for ages![]()
Yep, mines the Evolve, lovely interior on it. TBH, you won't find a better handling car for the cost (although mine does have coilovers which made quite a difference so forgotton how it originally handled but I had no complaints as such,)... it's a shed laod of car and the rest of the thing is bullet proof tbh... as long as you put some coin away for the inevitable engine problem, and uprate the oil cooler when it goes and you repair, jobs a good un!I actually think I might buy one next year to go alongside the 911, that way I will have 2 cars with engines made of cheese. From what I can gather pricing seems low across the board:
http://hextablerotaries.webs.com/
4k gets you into basically any car on that site including Evolve's and Kuro's, The R3 and the Anniversary editions seem to demand a bit of a premium. They are almost disposable cars at that price imo and it sounds like around 2k will get you a decent rebuild should you need one.
How much is the car worth if the engine hadn't gone boom? (Is there any reason to protect what you paid? Special deal or something?)
How much did it cost you to fix it (and what exactly was the problem in the end?)
