I've got the 60LM, which is really good to use. Much clearer than the smaller models IMO.
And you don't find it too obtrusive/large for use in a regular vehicle?
Do you mount it on the windscreen? Or have you got a dash mount?
I used to use it pretty regularly in my Picanto, which made most things look huge. I mounted it on the windscreen, but very low so it was just above the dash in the centre.
I definitely wouldn't choose to buy a smaller one. When I'm driving I like being able to glance and quickly work out what's happening - much easier if everything's a bit bigger.
I have mine on the windscreen but set so it's easy to glance over at - which the 6" size makes it perfect for. Nice loud speaker too which is key - can't always look over at it!
Very happy so far!
YOu dont find it tooo huge then? I'm used to having my onw below the rear view mirror!
Yeh, I think the 6000 is just too big... I'll get the 5000. Shame as the resolution is a lot lower, but I'm sure it'll still do the job absolutely fine
+ It's about £20 cheaper...
It really isn't too big, unless your driving the smallest car in the world.
Where are you putting yours then?
On the right side, behind the A pillar, attach the mount to the dash.
