I think my 980 GTX is on it's last legs!
MrMD here is my bios
https://mega.nz/#!z8dRSa6a!PtQ0L2Qfxa3ze0IpN0tGva3H_wscITfCFyyC40zji5k
Volts are set to max 1.275v with boost clocks of 1500mhz / mem of 3000. I'll be manually overclocking those rather than set boosts.
This bios has already been pretty heavily modded
When you just run the card without touching after burner what boost clock does it reach,as the boost table has been altered?
Edit: Ok from the modding already done to the bios,i only had to changed one single value on the voltage table.
Im confused by the boost settings on this card,the boost table has been altered to allow 1569mhz boost.But in another section its has been boost limited to 1493mhz.
With this bios it should just boost to 1493mhz on its own without touching afterburner
https://mega.nz/#!T8wzzTTK!8tKuI99dR1-9BZseMdgNT_imlvSZOW9gR4nXGzH_82Q
1493 on the core / 3000 on the memory
However I'm currently testing with K-Boost for higher clocks
right ok that makes sense,why was the boost table altered to allow 1569mhz then just to nerfed soemwhere else in the bios lolol
check my edit above for link^
Fantastic cheers, does that mean I can increase the clocks in MSI as per usual?
Yup
Core clock/mem clock powerlimit can be altered just as before,only the mV setting will do nothing.
In games/3d apps Vcore should always be 1.275v. regardless of gpu load/clock speed
Good luck :)
Just open AB and load a game up,even just sittin in the menu of a game you will notice the voltage change in effect
Yep, had to put it on Adaptive in Windows to get it to drop to normal votes. Time to try a game
