Need to find myself a nice key lime pie flavour, really have a craving for some limey style pudding. Does anyone has a diy mix for it?
FA Custard 1%
FA Vienna Cream 1%
FA Lime Cold Pressed 2%
FA Lemon Sicily 2%
FA Apple Pie 1.5%
FA = FlavourArt
Anyone got a list or recipe book of DIYs. Going to put an order in for some more concentrates/bottles etc last night but could do with some mixes to try as trying to mix my own isnt going too well. Is it worth buying some scales to mix by weight rather than syringes?
Can somebody recommend an atomiser (not a sub ohm) to go with an iStick 40w TC? Preferably one that doesn't leak everywhere like my Lemo 2.
God yes. Mixing yourself is a mega cost saving.
I mixed up a clone of Cuttwoods Sugar Bear last night. 100ml has cost me about £12 to make. To buy it's £9 per 15ml!
Recipe if you're interested:
4% Capella Cinnamon Danish Swirl
8% Flavour West Cinnamon Roll
1% Ethyl Malto (10% suspension)
4% Capella Sugar Cookie
83% VG/PG+Nic base
FA Custard 1%
FA Vienna Cream 1%
FA Lemon Sicily 2%
FA Apple Pie 1.5%
FA = FlavourArt
I just mixed 150ml of Red Astaire so did a quick costing, even when taking into account the P & P for the RA it came to under £16 for 150ml. I think their premade is around £5-£6 per 10ml so it's a big saving.
83% VG/PG+Nic base
You might find this site useful for recipes, tips etc.
I use syringes. Tip. if you cover the syringe with clear varnish or sellotape the markings will not rub off as quickly and last you longer.
Hey all.
Getting sick of my evod 2 gurgling and going from easy to suck to hard to suck and ive tried everything even cleaned one out under the hot water tap etc but i still have issues. Also it leaks a tiny bit onto the battery push pin thing.
So was wondering. First is it the tanks or batteries or just that the dual coil atomisers that is the issue, ive tried a few of the spares i had they dont seem to improve much. Oh and flavor seems not to last long.
So if its a new tank and atomiser thing i need but the batterys fine, what would be a good one that doesnt gurgle, leak liquid or condensation onto battery pin and always is easy to suck and is easy to refill.
Not too expensive either. No more than a tenner and it better last and easy to clean all parts if i get a one that expensive.
1% Ethyl Maltol (10% suspension)
83% VG/PG+Nic base
from the capella website.
Do any of your flavorings contain Diacetyl ?
We do not use Diacetyl in ANY of our flavorings.
Even though Diacetyl is on the FDA approved GRAS list for flavoring manufacturers, there are other compounds available to mimic a buttery/creamy taste.
Back to Top
Im assuming they may use other ingredients that contribute to it by what you say?
Independently laboratory tested Diacetyl free. Contains .371% Acetoin.
