Man of Honour
 - 13 Nov 2009
 - Northampton
Some more noob advice needed please
I have an istick 30w and a Lemo 2 tank (0.5ohm coil) which is causing me nothing but grief. I've coupled them with some Jax 12mg 25/75 vanilla custard juice and at the moment all I have is dry hits and a horrible burnt taste along with the Lemo 2 leaking everywhere.
I'm going to give it one last chance today, going to clean and rebuild the whole thing, new coil, new cotton the whole shebang. I did this a few weeks back but to no avail. I'm aware of the basics like wicking the cotton and starting off on low watts.
Thing is, I usually keep it at around 8w as this keeps flavour but I'm finding it doesn't quite hit the spot in terms of throat hit etc. As soon as I wack the watts up then I get the burnt taste and irritated throat. Is the setup capable of 15w-20w?
What gauge wire and how many wraps for your 0.5ohm build.
For wicking I find the cotton needs to move slide back and forth in the coil with a little bit of resistance then pop the chimney base on a trim the wick a couple of mm longer then tuck the wick down the sides but not to far to cause it to block the juice holes.
Have you tried a lower nic strength in it? I can chain vape my way through a tank in a couple of hours @ 50w with a 0.5ohm build (7 wraps 26gauge twisted) without dry/burnt hits so its more than capable of 30w.
As for leaking are you filling it exactly as the instructions? The only time mine leaks is if I forget to close the air hole or don't fill it horizontally
