Can anyone tell me what gains if any i would get from ocing the memory on my card.
Supposed to help with higher resolutions, I think. Most of what I've read suggests that overclocking the core gives better performance.
Not a huge amount, but I can do +500 easily, most can do +400 with minimal problems so every little helps.Can anyone tell me what gains if any i would get from ocing the memory on my card.
The bottom pic is showing a clock of 885, did the display divers crash by any chance?, you have to restart MSI if that happens.
I can get about +500 myself (gone higher for 3dmark runs) but I just have memory set t default as I never really seen any preformance gains in games
Are you using the base bios?.No difference. I can get the clock higher using other tests, but this is the first GPU that I have had that caps out at low TDPs, I would expect it to say TDP = 100 and then PerfCap = Power.
Any news on when the GTX 980 Ti classified will be available?
The extreme is mental looking, seen a pic of it installed into a case and you'd think the pci-e slot was gonna snap, it was sagging like a flaccid donkey wang.![]()
Mine was the same and i had to make a custom jack, I just felt so uneasy leaving it sagging so much.
Can anyone here with an AMP Extreme chime in on the sag? I'll be getting one soon and it's something I've been worried about given the sheer size of it.
Would make me want another silverstone raven case if I was running these huge aftermarkets on air.
The vertical motherboard setup on my second system is great for heavy coolers, also better for cooling tbh. It's a shame more case makers don't adopt it, mine was fantastic (just a little too small for the watercooling setup I've got).
To be honest my arctic accelero on my 7970 sagged that much due to lack of back plate and I had it in my system for a over a year with no problems. In fact it has been in my brothers PC for another year no problems. I wouldn't worry about the sag.
Backplates really don't help all that much for rigidity, they do a little but some cards have backplates and still sag. The asus strix 980 ti has a metal bracket along the pcb which reinforces it from sagging.
