My D7000 should be here today![]()
Mine is coming tomorrow - let us know how you get on setting it up
FYI the new D7000 does not reboot itself or lose sync when you apply the majority of settings and if it does need to do something that takes a while it seems like the modem part and the router part are separate parts and it does not have to take both down etc ))))
Just a small update for those trying to get IPTV to work, it does cover how to set it up in the manual...
http://www.downloads.netgear.com/files/GDC/D6400/D6400_UM_14May2015.pdf
bottom of page 197 and onward from there, basically the same as on a billion, enabling WAN2 and setting a bridge.
I am about to send back my D7000 as I couldn't work out how to set up IPTV on it - it just did not work - this is the link I was trying to use: http://kb.netgear.com/app/answers/detail/a_id/29326 - it did not work - you mention page 215 which is the same for the D7000 - enabling Lan 4 in bridge mode - do you just tick that box and apply the settings? If that is what you did, can I only use Lan 4 for the IPTV? My current set up is a 10m cat 6 ethernet from the router to a gigabit switch behind the TV which connects my apple tv, blu ray, tv, laptop etc. So I would only be able to use the youview box direct to Lan 4 - does that make sense?
I know this is a big ask - can you take a look at the manual and give me some advise? http://www.downloads.netgear.com/files/GDC/D7000/D7000_UM_01July2015.pdf
There are IGMP options in the D6400 and from reading the manuals the D7000, you can not be configuring things correctly or following the instructions correctly if you get no such options.
I do not have any form of IPTV otherwise id do a step by step picture guide, doing so without IPTV though would be a bit difficult as i would not know if what i suggest would work 100%.
D6400 Firmware Version 1.0.0.34
New Features & Enhancements
Wireless driver update for CE 2.4GHz power issue
Removed IPTV / DHCP option 60 in Setup Wizard while it’s set to UK/Sky and VDSL mode
Added ISP option list in Setup Wizard in ETH-WAN DHCP mode
Wireless AP mode picture update (for D6400)
DSL quick scan table updated
Added DFS channels support in Europe and Australia
Removed the Setup Wizard log
Added IPTV option in Setup Wizard for known ISP, It will bridge LAN4 and VDSL VLAN 30 interface
Disabled VLAN option in Setup Wizard page (user cannot change it in Setup Wizard)
Wording change in Internet Setup page / Router Status page: WAN1 to Internet, WAN2 to IPTV
Added “WAN2 bridge to LAN4” option in Internet Setup page
Added XAgent (Remote Genie) support
Updated DSL PHY driver and enable SRA and G.INP support
Added NA sku support
Internal wireless parameter change : watchdog from 60000 msec to 3000 msec for Home IOT issues
Bug Fixes
Fixed the issue with Wireless Setup page on Chrome browser
Fixed the issue where OpenVPN information incorrect in non-English version
Fixed the issue where upgrading the FW through internet crashes the router
Fixed some issues happened in WPA/WPA2 Enterprise Test
Fixed the issue where Asia 5GHz GUI channel can't set 36,40
Fixed the issue where router statistics show incorrect LAN interface uptime
Fixed the issue where BT WAN detection fail at ETH mode while IPTV is enabled
Fixed the issue where LAN PC doesn't get IP address from WAN when enable IPTV from VLAN / Bridge Setup page
Fixed the SoapAPI: Many API run failed during SOAP testing
Fixed the issue where browse button is not translated into Chinese on Setup Wizard restore router settings page
Fixed the issue where there is no ReadySHARE Vault option in USB function
Fixed the issue where Wireless client can't connect to router when its security mode is WPA/WPA2 Enterprise with EAP-TLS authentication
Fixed SOAP vulnerability (Need password requirement for SOAP API)
Known Issues:
PnP-X driver is not ready
	http://www.downloads.netgear.com/files/GDC/D6400/D6400-V1.0.0.34_1.3.34.zip
Code:D6400 Firmware Version 1.0.0.34 New Features & Enhancements Wireless driver update for CE 2.4GHz power issue Removed IPTV / DHCP option 60 in Setup Wizard while it’s set to UK/Sky and VDSL mode Added ISP option list in Setup Wizard in ETH-WAN DHCP mode Wireless AP mode picture update (for D6400) DSL quick scan table updated Added DFS channels support in Europe and Australia Removed the Setup Wizard log Added IPTV option in Setup Wizard for known ISP, It will bridge LAN4 and VDSL VLAN 30 interface Disabled VLAN option in Setup Wizard page (user cannot change it in Setup Wizard) Wording change in Internet Setup page / Router Status page: WAN1 to Internet, WAN2 to IPTV Added “WAN2 bridge to LAN4” option in Internet Setup page Added XAgent (Remote Genie) support Updated DSL PHY driver and enable SRA and G.INP support Added NA sku support Internal wireless parameter change : watchdog from 60000 msec to 3000 msec for Home IOT issues Bug Fixes Fixed the issue with Wireless Setup page on Chrome browser Fixed the issue where OpenVPN information incorrect in non-English version Fixed the issue where upgrading the FW through internet crashes the router Fixed some issues happened in WPA/WPA2 Enterprise Test Fixed the issue where Asia 5GHz GUI channel can't set 36,40 Fixed the issue where router statistics show incorrect LAN interface uptime Fixed the issue where BT WAN detection fail at ETH mode while IPTV is enabled Fixed the issue where LAN PC doesn't get IP address from WAN when enable IPTV from VLAN / Bridge Setup page Fixed the SoapAPI: Many API run failed during SOAP testing Fixed the issue where browse button is not translated into Chinese on Setup Wizard restore router settings page Fixed the issue where there is no ReadySHARE Vault option in USB function Fixed the issue where Wireless client can't connect to router when its security mode is WPA/WPA2 Enterprise with EAP-TLS authentication Fixed SOAP vulnerability (Need password requirement for SOAP API) Known Issues: PnP-X driver is not ready
Try the d6400 manual here...
Read page 196 all the way up to end of page 204. Then also have a read of page 206 to ensure IGMP is properly enabled. Page 205 about the DMZ server you should be able to ignore, thats not needed leave that well alone.
Im assuming the web setup is basically the same on the d7000.
I also have a upload a manual about how to enable iptv on a billion 8800N which although a different device may be of some use as it has the odd helpful picture and some specific settings.
http://go4up.com/dl/13ae62b57ef0
This may or may not confuse the issue more, some people find some methods of describing things easier to follow that others. Personally i think the netgear manual is pretty clear on what you need to do.
If you still can not get it working i dunno how to help further![]()
