Could you please check your BIOS for me and confirm whether or not you have the setting to change the gen for all 5 slots.
you can find these settings under Advanced > System agent configuration > NB PCI-e configuration
I only have the option to change slots 1,2 and 4
If I select "load optimised defaults" then I have the option to alter all 5
Until....I reboot then they are gone again.
Thanks
Thanks
