How do I recover a formatted hard drive
You could try the likes of recuva and Pandora recovery. Make sure you use deep scan and a second drive to recover the files to.
Getdatabackforntfs.
Restore it to another drive.
Alternatively, you can easily just restore the data from your backu....
Getdatabackforntfs.
Been using this on a backup drive that somehow got formatted during a windows 8 image restore. What is even more strange is that a partition was made with the same name and size as my games ssd but left completely empty.
Slow as anything and did crash after I pressed the wrong button but seems to be doing a good job.
Your backup drive got wiped?
Easy solution, copy your data back to the backup drive.
If it was the only copy of the data, then it isn't a backup drive.
